Numeric Racing Short Throw Shifter for 991.2 Manual GT3
#31
Basic Sponsor
2 mm is the stiffer spring. There is no force required to put it into neutral. Just pull it out of gear and the lever automatically snaps back to neutral. The 1.5 mm is similar to the GT4 and GT3 shifter.
#34
Location: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
are the cables needed to make a true difference vs the stock GT3 one?
#38
It means the SS Kit
takes out much of the play found in the OE shifter design.
And, the replacement cables take out some more play (found in the OE cables) for an even better shifting experience.
Beyond that, you should speak to Dan at Numeric Racing.
#39
Wow, considering that the GT3 Manual is my 10/10 in manual transmission in terms of accuracy, feel and action.
Are you sure that the Short shifter is that much better than stock? I just can’t imagine it can be any better
Also did you try to power-shift? Any issues going from 1-2 and 2-3 without lifting the throttle?
#41
Special delivery! Hope to get some time this weekend to install.
NCheok (07-18-2019)
PhoenixINX (11-26-2020)
#44
Basic Sponsor
Hello Holdens
You probably got a shifter with the stiffer 2mm spring. The 991 Carrera and S models stock shifter does not come with a centering spring. Only GT3 and GT4 came with the added spring which is a 1.5mm in diameter. I can swap the springs out and you will have less tension moving the lever left and right. It will be the same feel as the GT3 and GT4 except the throw is shorter. The stock shifter just has so much flex to it and not rigid at all. Plus everything is billet and stainless steel and uses bearings rather than plastic bushings.
#45
Just watched the video for a 3rd time. Gonna go for the install now. Why wait? : ) wish me luck
FlyingLow747 (08-02-2022)
