GT3RS downforce adjustments
Sorry but I’ve searched to no avail. I’ve read before on this forum about removing some of the aero elements under the car to assist with increase downforce. I’ve angled the rear wing with the leading edge lower than the rear (see attached pictures ). Also for those that have made these adjustments any real world feedback? Thanks in advance.
Stock setting
Adjusted for increased downforce
Stock setting
If I recall removing the screw on aero elements by the wheel under the car is the answer. Didn’t know if made a noticeable difference.
The 991.2 3RS has four levels of adjustment for downforce. The factory sets the wing at the 2nd lowest position or 2nd most rear downforce.
The front undertray has the lower blocks in place similar to that on GT4. You should remove them if you go the higher angle of attack to balance the car.
I have my car set on the highest angle of attack on the rear and the aero blocks removed.
So far I find the car is well balanced. I am also running canards/gurney on my car. I am going to dial out some camber out of my car; I am running a little more than my 991.1 RS and I don't think it needs that much based on they way my tires are reading and stiffer springs. I am going to back off to around -2.8 rear and -2.6 front.
- Chris.
- Chris.
- Chris.
- Chris.
The blocks in front of the wheels. Two screws. It affects the airflow going into the wheel well. Also remove the screens for the fender vents. two screws.
Clearly for. both instances, be sure to put the screws back to their originsl holes.
And what size are the screws?
Thanks, (Going to Spa tomorrow)
Originally Posted by wareaglescott
Did they actually modify it by making more adjustable positions or do you mean they just changed the setting to one of the factory provided options?
