Orthojoe's GT3RS thread: ED and the end of an era for me
#301
Thank you Joe
From everything I have read and heard the performance difference is real.
Some of the speed I suspect comes from the taller but narrower rear wing.
I don’t know downforce numbers but I think they got more overall, yet smaller wing!
Look forward to more tire info, getting tired of failing Hoosiers, but love the lower center of gravity the 19” provides.
Higher spring rates, different dampers and away bars also make a big difference, specially on fast, smooth tracks.
The rest of the lap time comes from a little more HP and new tires.
Aero
Suspension
Tires
HP
Im excited to drive it. Going to be a long 4 months waiting
Aero
Suspension
Tires
HP
#302
Joe, if the RS vmax was 5mph higher and it was only 0.7s faster than the GT3 (with manual), doesn’t this mean that the GT3 was faster (or at least) equal in the turns (slower sections of the track)? Logically, the laptime diff should have been larger. Could also be different track conditions on different days. RS dunlops and GT3 cup2s were both fresh, correct?
Lizzard RS looks awesome on the track!
#303
Joe, after your review, tirerack is going to be out of stock on Dunlops. It's my preferred tire too.
I'm looking forward to seeing you get into the 1:33s and smashing the regional GT record. It should be no problem for you - you lost time in T2, not early enough on the power in T5 or T9. I think a 1:32 is in the cards too.
#304
Thank you Joe
Aero
Suspension
Tires
HP
Aero
Suspension
Tires
HP
#305
GT3 player par excellence
THERE IS A REASON WHY I TELL EVERYONE CUP 2 IS THE BEST....
u don't see me on cup 2 muhahahhhaa
#308
#309
People have reported two different sources for oil leaks that I've noticed posted. A leaking oil tank (poor welds at the seam) or a leak from the oil hard line as it enters the crankshaft (for oiling through it). First will drip on ground or right front corner of tray and second will drip more towards the rear of the tray (centrally) and you can often see a droplet formed on the underside of the main drive belt pulley.
#310
#311
Originally Posted by TRAKCAR
I just ordered slicks to try, your Dunlop’s are safe. For now..
Oil from where, perhaps has something to do with delivery stop.
Have you removed diffuser to look.
Originally Posted by .dee
where / how did you notice this? am forever mindful of this with mine. Many thanks!
#312
Hmm, so now we have oil leak from faulty oil tank seam, then oil tube at crank pulley area(me and my friend’s GT3), and now front left side oil tube.
Its seem oil is leaking from all over the places, so much for Motorsport engine..,.
#314
Originally Posted by STALKER99
Update regarding the oil leak?
2nd day on the Dunlops and the car was running consistent 1:34s at laguna. Outer edges of front and rear tires are wearing and insides look barely worn. Tires have one day left based on this wear pattern. Stock camber from the factory was -1.5 on all 4 corners. I'm a glutton for punishment and had my mechanic increase it to -2.5 on all 4 corners. Let's see what happens with those numbers on Dunlops.
