.2 GT3 RS track set up
Anyone have advice on set up of the .2 for the track? Sounds like the .2 will need less suspension tuning compared to the .1.
I assume add camber to the front and rear, say -2.7 F/-2.6 R, Toe F 0/R 4mm and corner balance as well as take the mesh out of the front fender vents. Ride height adjustments?
I haven't read about rubbing issues, so I assume no need to roll the fenders like the .1.
Congrats on the car David, looks hot with WP. I would add camber, maybe adjust the height a bit, add adjustable sway bar links, and then do an alignment with a corner balance after you install a roll bar, harness, and seat brackets. Take out the mesh screens off from under the front fenders. Springs should be good to go and I wouldn't roll the rear fenders. I be taking off the side mufflers and installing a lithium battery then adding a quiet center muffler so I don't want to blow a hole in the Ti muffler. haha
I'd talk to the boys at bbi.
Congrats on the RS, Dave.
coming from a GT4, i am looking forward to learning from ya'll about the setup on the .2 GT3RS. i absolutely loved running 19" bridgestone RE71R tires on the GT4 over the stock 20" cup2's which were quite a bit cheaper too. any recommendations on wheels/tires for the new RS?
I've heard opposing opinions, but I think the concept is you can get more clearance in the front wheel wells with the screens out, so you can lower the car/center of gravity; gains a few 10ths per lap perhaps.
