Brake fluid stain on caliper
So I had my local dealer replace brake the fluid w SRF , in doing so there are some drip marks
any suggestions that works good removing them?
You need to repaint the calipers. Brake fluid is caustic to paint.
Ryan
looks like we will be having the repainting conversation , I have steel rotors
This is what may have happened. Residual fluid was left over in the top of the brake line valve and boiled over under high temp loads. I blow out mine after bleeding the brakes so this does not happen.
