What questions do I ask a tire shop before letting them touch centerlocks?
#46
I'd just have 2 fronts replaced, and put the used ones up on craigslist to see if anyone would take them off your hands cheap
When the time comes at the end of the year, just replace the rears and keep on enjoying the car!
#47
Typical green student tire wear. The fronts wear out faster than the rears.
Seriously. Rears normally wear out faster than fronts on these cars. If you are already this low on tread on the fronts I would double check the rears. Its also not only tread depth but heat cycles that will come into play here if you only replace the fronts. Hint: green student learning curve.
One of the used ones is garbage. I can't sell an un-repairable tire with a puncture in it. The other will be kept as a spare though on the off chance I happen to go through this again and it's of any use.
