Trailer Experience/Recommendations
fester (02-05-2020)
#93
Awesome way to store the trailer - was hoping I could do the same thng. The width of the trailer looks tight for the GT3. Do you have to use the winch to ensure that you align the car when loading?
#94
Yes one the reason I bought this model is because I knew it would fit inside garage. I was surprised to see that it was a bit tight and yes I did use the winch to load the car. Great set up I'm really happy with it.
#95
I went with the Aerovault. Had my first real drive with it last weekend. About 250 miles to NCM, I usually get about 9mpg with the open featherlight. I got 12.5mpg with the Areovault. I also notice it tow's very effortlessly.
At the event it's nice to sit in, although it's to short to stand in.
You can also keep a extra set of tires and your basic tool in it all the time, you can keep you car in it if you want. Also the LED light are nice.
They are a bit pricey, around 20K.
#98
#99
Then you tilt the bed down to the ground, the fact that the back is on the ground holds the trailer in place - no hook up to vehicle needed. Then you can drive on or winch on the car. I can load my 3,800 lb Z/28 on the trailer without it being hooked up to anything as well.
Put trailer in down position
Winch car up and raise trailer bed up
cadster (02-05-2020)
#101
I trail my GT3RS on an open Trailex with my base Cayenne.
Works a dream and the trailex is extremely stable.
No door issues.
I do use the small race ramps and a 2by4 under each ramp for loading.
No problems loading, consider the rennsport attachments, very easy on this model.
Good Luck!
No door issues.
Good Luck!
fester (02-05-2020)
