Cold tire pressures for 2018 991.2 GT3 4.0?
Owners manual, door sticker, etc
OR
Are you talking about cold track pressures
OR
Those are the best pressures for the street. More air then the recommended will make the ride rougher. Less air then stock you run the risk of loosing a rim or tire on the street (at least around where I'm at)
On track I tend to go out with 26psi cold and warm them up gradually (first through braking then by zigzagging). After a couple of laps at 90% I then drop them such that I can drive them hot at 29 to 30 psi.
Received 5,414 Likes
Originally Posted by white6speed
Have you guys heard of increasing tire pressure of a stored (winter) car to 50 lbs to avoid flat spots. Normalize pressure prior to driving.
Originally Posted by Kobalt
I do this even if it just for some weeks.
On modern street tires, flatspotting from extended storage is way over-blown, easily avoided, and reversible upon a good heat cycle.
True, Sometimes when I leave my daily driver at the airport (outdoors) for a week or so I can feel how the tires are not round anymore when I start to drive home, when I'm home the tires are OK (20 minutes drive).
To 50 lbs??? That is unnecessary. I usually just add an additional 5 to 8 lbs. and I lose very little in the Chicago cold for 10 weeks. After 6 weeks try to catch one decent day to take around block to rotate the tires but I bet if I left it there for 3 months would have no dead spots.
Thanks. And yes, certainly here in the mega-potholed unrepaired streets of Maryland (where your taxes go to corruption and fraud, and zero infrastructure), I often think I'll lose half an axle...
