Backup camera - strange behavior
My camera stays on if I push the rear window defroster button 3-4 times quickly. It stays on until you shut the car off or hit the defrost button again. I use it at the track since the rear mirror in the GT3 is worthless. Not sure if it works the same on the .2 but it does for Nav TV which uses Porsche PCM programming, so unless they changed it in the .2, it should work.
^Huh, will I also wake up in Kansas??
My car is all tucked away and I am depressed because I want to drive her and the weather sucks here.
Can any one confirm if this works
Also the 991.2 has a different PCM. Maybe somebody will figure out a video in motion module and release it.
