Survey of 987 Owners
Old 06-21-2017, 02:27 PM
CJFusco
CJFusco's Avatar
Default Survey of 987 Owners
I'd like to conduct a survey of 1996-2008 Porsche owners in order to get an idea of what kinds of preventative maintenance have the most value/effect. Whether your car is healthy or if you've experienced an IMSicon failure or bore/cylinder scoring issue, please share. I will post this survey in a number of forums and compile the information in order to get some conclusive data on what works instead of just relying on circumstantial evidence:
1) The year, model, and mileage of your Porsche the last time you drove it (i.e., at the time of failure, if it experienced one)
2) Did your car experience either an IMS or cylinder-scoring-related engine failure?
2a) Did the failure occur on a racetrack?
2b) What was the nature of the failure?
3) What oil is/was used in the car?
4) Did/does the car have a LN engineering spin-on oil filter, or the stock oil filter?
4a) If the filter was a spin-on, did/does the car also have the extra magnetic strip installed?
5) Did/does the car have a magnetic oil drain plug?
6) Did/does the car have a 3rd radiator installed?
7) Did/does the car have a low-temp thermometer installed?
Old 06-21-2017, 03:33 PM
Suicide Jockey
Suicide Jockey's Avatar
1) 2005 Boxster S, 34,xxx miles
2) No.
2a) N/A
2b) N/A
3) Mobil 1.
4) No.
4a) N/A
5) No.
6) No.
7) No.
Old 06-21-2017, 04:45 PM
johnnymiz
johnnymiz's Avatar
1. 2008 Boxster LE (orange), 52,xxx miles
2. no
3. mobil 1... every 3,000ish miles
4. stock filter
5. no
6. no
6. no
other than consumables (tires, brakes, oil, battery), the ONLY repair work it has ever had was a new air-oil separator last week. Best car ever.
Old 06-22-2017, 08:13 PM
CJFusco
CJFusco's Avatar
Thank you for all who have contributed so far. Please keep them coming!
Old 06-28-2017, 04:27 PM
Jerrygreene
Jerrygreene's Avatar
1) The year, model, and mileage of your Porsche the last time you drove it (i.e., at the time of failure, if it experienced one) 1997 114,000 yesterday. Top would not go down around 55,000
2) Did your car experience either an IMS or cylinder-scoring-related engine failure? no
2a) Did the failure occur on a racetrack? na
2b) What was the nature of the failure? na
3) What oil is/was used in the car? mobil 1
4) Did/does the car have a LN engineering spin-on oil filter, or the stock oil filter? stock
5) Did/does the car have a magnetic oil drain plug? no
6) Did/does the car have a 3rd radiator installed? no
7) Did/does the car have a low-temp thermometer installed? no
just replaced all three this summer, car is now tons cooler running...
Quick Reply: Survey of 987 Owners
