2013 Boxster Washer Fluid Hose Snapped - Part Number?
Hello guys. Accidentally posted this in 986 forum so posting in correct forum. So, my 2013 Boxster's washer fluid hose snapped actually over a year ago due to the bad placement of it with the trunk opening and closing and now I want to replace it myself (I waited that long due to my car only being driven in the summer)
My question is, what is the part number for this hose? Is it this one from this website number?
Please help me confirm the right part. Thanks a bunch guys!!
http://parts.byersporsche.com/p/Pors...162866705.html
This rigid plastic tube snapping is a common problem. Instead of replacing it with a new one which will likely break again just trim the tube back around where the break occurred and slide heavy duty rubber fuel line tubing over each broken end. You want the inside of the rubber fuel line to fit tightly over the plastic tube. You want the fuel line to be thick enough to where it wont kink while bending to the small degree it has to. That's what I did and it should last for a very long time. I didn't even need hose clamps it fit so tight.
