2007 base Cayman brake parts- quality?
Old 04-01-2017, 07:21 PM
Chalkboss
Chalkboss's Avatar
Default 2007 base Cayman brake parts- quality?
My wife's Cayman needs front and rear brakes (pads, rotors, sensors). I am doing the work myself. Car is not tracked or autocrossed. I just need decent quality stuff. Car has 63K miles on it.
I've used Zimmerman rotors on my 928 and like them, but I see there are many pad/rotor manufacturers. What is a decent pad to use but not outrageously priced? Also, are the Sebro rotors any good?
Thanks!
Old 04-01-2017, 09:28 PM
HoBoJoe
HoBoJoe's Avatar
Sebro rotors are good to go.
Old 04-23-2017, 10:38 PM
MrSlacker
MrSlacker's Avatar
Has anyone used Textar rotors?
Old 04-24-2017, 12:17 AM
HoBoJoe
HoBoJoe's Avatar
Textar is an OEM supplier, they should be good.
Old 04-25-2017, 02:54 PM
Chalkboss
Chalkboss's Avatar
I just received the Sebro rotors. They certainly look like very nice quality rotors. I am waiting on pads and sensors and I will post my impressions once I get the job done. Thanks for the tip HoBo!
I ended up ordering ATE front pads and Textar rear pads. Sensors are Sebro.
Rotors were worn past discard spec- which is a bit surprising considering they lasted only 22K miles. The PO had the fronts replaced at an Indy shop. No idea yet as to what brand they put on, or the pads. He did do some autocrossing but still...
Old 05-01-2017, 01:18 PM
Chalkboss
Chalkboss's Avatar
Finished this job up over the weekend. Very pleased with the parts I ordered, certainly met my expectations. Rotors were a few tenths of a mm from discard spec but I did them anyway, brakes feel great. It's nice for once to work on a Porsche that isn't 30 years old (my 928)!!
Old 05-11-2017, 12:05 PM
porscheaddicted
porscheaddicted's Avatar
What brake pads did you install finally?
Old 05-15-2017, 09:45 PM
Chalkboss
Chalkboss's Avatar
Front are ATE and rears Textar. They dust far less than the brembos that I replaced, which is an unexpected bonus. The sensors are Sebro, which fit perfect and had the correct grommets for support on the rear brakes and shielding- at a fraction of the cost of OEM of course!
Quick Reply: 2007 base Cayman brake parts- quality?
