spyder top procedure question
Yes, do be very careful with this. I found if I tried to move just the top without the latch it hardly ever lined up right. What I do now is I hold the close top button very briefly and it'll move the hook closer to the closed position. Then I'll move the hook into place, and then hold the close top button again.
This is less prone to removing fingers.
Without doing this I can never get the top closed without it popping out.
here is what I do:
Pop rear trunk and pull out roof all the way. Then go back and close the trunk lid but not all the way. I then pop the winged buttress things off and stick them in to the car slots until click sounds happen. Once that is done I sit in the car and pull the roof down all the way and press the roof lock button. The hook goes in and locks the roof and then I go and press the trunk lid shut. I find the lack of tension with the trunk lid a little open make it very easy.
I don't know if anyone noticed but you can see if they are fully engaged. Look on the underside while you push the button on the top of it. You'll see a red indicator sticking out. If you push the buttress down and the red indicator has not disappeared it means it was not correctly installed!
I check this each time I install them.
I never had a problem with it. But, I was taught at the factory a different order. Manually raise the top, attach buttresses, use power button to latch top, then close the trunk. Only once did I not have the top close enough to latch. It automatically cycled again, and latched.
The beauty of the 987.2 Spyder top is that it is all manual. There is no micro switch, no electronic latch.
Coming from owning Miatas, I like the simplicity of manual top. We are know the nightmare of broken Boxster top mechanisms. I am happy to report nothing has gone wrong with my totally manual Spyder top.
Brought my car to the dealer yesterday to have a look. It is not normal that the hook doesn't engage without manual intervention. And indeed, after a bit of checking things out they discovered that the entire hood system is not correctly aligned (the bottom part, inside the car).
Will need to take the car back to them next month, they need an entire day to disassemble everything and get all pieces aligned up correctly.
There seems to be an easy way to check this. With the roof latch closed and the flaps attached to the rear of the car, open the rear trunk carefully. On the side (underneath the "Spyder" logos) you can see some kind of horizontal cilinder that has to fit in a fork (hard to explain it, should take pictures). You could clearly see those 2 pieces weren't correctly aligned.
Also, once the hood is correctly latched, unlatching and latching again works flawlessly because everything was correctly aligned because of the first latch. It only goed out of alignment when opening it completely and closing again.
I hope I made some sense
Tried that. Didn't change a thing.
i find that it's a bit hit or miss, mostly works, occasionally need to redo a few steps. overall quite good and love the design. wish i had the bikini option for sure. maybe some aftermarket company would make one.
It's just impossible to have the latch work without fiddling with the roof while operating the button, and it seems to get worse over time on mine.
Anyone else experiencing this? I had it snap out very violently once during closing because it caught on the edge, sometimes I get errors and the rear trunk pops open again, and when I want to guide it in from too far the car refuses as the roof is too far open for the system to start engaging.
I find the top very easy to close. I always park the car with the top up, so I don't get those unsightly disk-shaped impressions on the top. When I walk up to the car, I hold unlock on the keyfob and it pops the top and the trunk as I get close to the car. I disconnect and plug in the buttresses, open the trunk, fold the top down inside, and close the trunk, then flop the side flaps over.
To put it up, I hit the close button inside, which drops the windows, and pops the trunk. I get out, open the trunk, flop the top up, and then close but not latch the trunk. With the trunk resting on the latch, I plug in the buttresses, and then go inside, and fully close the top with the switch. Most of the time, it just closes, occasionally when it is very cold, I have to pull on the top of the top from the inside near the windshield header (there are plastic grips on the top inside to facilitate this) and then cycle the close switch. After the top is fully buttoned up, I then fully close the trunk.
The one other tip I received at the factory was that once you clip in the buttresses, make sure you look across to the other side and you can't see the little red pin - as that means they are fully engaged. Apparently a guy didn't have one fully engaged and it came loose causing damage as it flopped around at speed.
