Disk on outside of Boxster S transaxle
What does the indicated disk on the outside of this Boxster S transaxle do? I am using this transaxle on a home built car and the disk is in the way of a frame tube that I want to add. Can I remove the disk and the linkage?
Many Thanks,
Enzo
Many Thanks,
Enzo
It is simply a counter weight to help you with the shifting feel. I removed it from my race car and saved 1.8 lbs.
It will move when you shift but the linkages are prone to come loose and just dangle around anyway.
