Boxster as track car without roll bar
Basic question is, do most track days allow Boxsters without roll bars? Is the built in roll over protection considered good enough?
We are looking at buying a day to day/track car. The wife really wants a convertible(this will be her car) but we will track it.
If it comes down to Cayman/Boxster the qualifier will be if we can run the Boxster without having to add an intrusive roll over system. She will DD this in the summer and maybe 5-6 track days per summer so putting in a real roll over protection is not in the cards.
If she cannot track the Boxster she will look at a Cayman.
They are allowed as long as you pass the "broomstick test". (There should be space between your helmet and a broomstick resting on the roll-hoops and the top of the windshield frame.) 987 and later (2005+) models usually have no problem passing. Bray-Krause made (makes?) roll hoop extensions for 986 but are not needed if broomstick test is passed without them.
I think they will ask you to run ( driver ed ) with the roof up, unless you have arm restraints ( requiring seats and harnesses ). Much better than a good day at work either way... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Donn
Donn
Also suggest check with the event organizer you plan to run with. Most allow Boxsters in my experience but I recently attended a BMW CCA and noted they don't allow convertibles.
We run our own DE's and let convertibles run but wanted to do more events.
I assume PCA allows convertibles to run. We want to travel a bit more for events and if most allow them I'd be good. Sometimes tracks themselves have restrictions.
The roll bar extension looks great especially if you can remove it for not being at the track.
Now time to start looking for a car.
Bottom line: you can't make assumptions. Ask the organizers.
Comment on the B-K roll bar extension- it's pretty easy to install but you do have to remove the factory roll hoop padding and the mesh windstops inside the hoops to clamp the extension bar to the factory hoops. The top opens and closes fine with the extension in place so I just leave mine on all the time. I have a 986, but the 987 is the same set up. Depending on the driver height with helmet you may not need the extension. The first Boxster I went to test drive I brought my helmet and a stick. Seller gave me a strange look!
Below is PCA's minimum standard for convertibles at PCA hosted drivers education events.
Cabriolet/Convertible Cars
Any make of car delivered with factory installed roll over protection meets the minimum standards for PCA DE events. In these cars we recommend the soft-top be in the up position or the hard top installed. If the top is in the down position, restraint system* must be used. An SFI and/or FIA approved arm.
If a car does not have factory installed roll over protection, a roll bar or roll cage must be installed, which meets the "broomstick" rule (the driver's helmeted head is below a bar placed on top of the roll bar and windshield). Design, installation and materials of roll bars or cages and their installation must meet PCA Club Racing specifications, contained in Appendix A-Roll Cage Specifications of the PCA Club Racing Rules. All targa tops must be installed unless there is addition roll over protection. All sunroofs must be in the closed position. The windshield alone is not considered to be factory roll over protection.
*Velocity Management, Inc. is a source for the SFI approved arm restraint system for use with the OEM three point belts. Contact info is www.gofastbesafe.com (link is external) and the part number is QE3ptArm
Aaron
Aaron
Interesting. So since Boxsters have factory installed roll-hoops, they don't have to meet the "broomstick" rule? That's not what's being implemented in practice.
The broomstick rule is implied with any open roof car. Only the older Boxsters ('96-'04) were an issues with drivers over 5' 8" tall. That was the reason Brey-Krause came out with their Roll Bar Extension.
If I was tracking at all I would want a roof over my head. Yes the chances of a rollover are slim but roll over into, or just hit, a tire barrier or soft dirt and bad things could happen. I refuse to instruct any convertible at all, even with a roll bar for the above reasons.
Yes I am old and crotchety![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Peter
Peter
I've run my 2013 981B for three seasons now at DE events mostly at Road America.
The Porsche OEM design is designed for roll over protection, windshield frame and roll hoops and I would trust the Porsche engineers better than any add on after market device.
As stated PCS requires top up unless you have arm restraints, you don't require a harness for amr retraints.
I purchased a pair of Simpson arm restraints and judged them the most unsafe thing I have ever put on in a car. I wouldn't even start the car with them on.
So I run top up unless it's an SCCA event where the SCCA understands modern roll over protection systems and lets me drive top down.
BTW, BMW will not let any convertibles drive.
How's that for a confused lot of bull$hit!-Richard
BTW, I am old, an Engineer and not "crotchety"!
Who would want to drive a hairdresser car on the track? Oh, me that's who. :-)
Before I caged it, I installed the Brey-Krause extender and enjoyed it as a wonderful dual purpose car.
