2007 Boxster Help with coolant filling
Hello all, I am new to the forum but I am hope you can help me with a problem. I have a 2007 Boxster with an automatic transmission (which does not have the burp valve in the back). I am trying to fill the coolant system and get it to circulate through the engine. I replaced the water pump and thermostat. I jacked the rear end of the car up, filled it with coolant, pulled the B1 fuse and ran the car at 2500-3000 rpm, adding coolant as needed. I have durametrics connected to watch temp since the instrument cluster is blank when you pull the B1 fuse. Oil and engine temp climb, the fans both engine and front radiator fans cycle on but the temp continues to rise to 95 Celsius. I am afraid to run it any longer. Also I have no heat, thoughts? Thanks for your input!
