987 Oil leak
Looks like all the pan bolts are there to me.
More importantly, what year is the car and how many miles?
Leak from an unmolested/untouched oil pan gasket is rare.
Are there any signs the pan has been bottomed out?
Have you reused the oil drain sealing washer?
Also, I have to point out there is a lot of engine above where that leak sign is. The leak could be from higher up, so before you condemn the oil pan gasket or the oil drain plug/sealing ring you need to carefully inspect the engine -- from underneath with the car in the air -- looking for any source of an oil leak up higher.
My thought would be the plug gasket. The oil on the lip could have easily been blown back considering that's at the rear edge. I would replace the plug gasket, clean and recheck before anything else.
