How To: Putting new springs into Cayman S
Alrighty I just bought some Eibach springs for my Cayman S 2006. I wouldn't normally have any concerns for doing this, but my car is equipped with PASM. I was just wondering if any of you guys had any videos or websites or anything to help me out with something like this so I don't ruin the electronics. Thanks in advance guys!
Addict & Guru
Here's a link to a DIY article for an oem PASM swap to Damptronic which may provide some guidance. The PASM wires come out the top of the oem shocks and are just disconnected to remove the coil over assembly from the car. Then it's the usual spring compressors, etc.
You should check and, if needed, replace the rubber bump stop while its disassembled. Consider that some shops cut down the rubber to match the lowered car, while others use Cayman R stops for the same reason.
Sending you an email with a related question.
