Durametric Help Near Elmhurst, IL
4th Gear
I recently gave up the battle of replacing a failed TPMS sensor each year as my Boxster S has come out of hibernation and since I also got new aftermarket wheels this Spring, I decided to have Midwest Eurosport in Bensenville disable the TPMS system all together. After working on it for a couple hours they said they could not do so. They did not charge me for the failed attempt, thankfully, but they also are unsure why it didn't work. We verified they were following the right coding procedure and also the box in the front trunk was also disconnected.
Anybody near me with a Durametric pro that can help? Gladly compensate you for the time.
2007 Boxster S
2007 Boxster S
I would code it for you but you're ~1500 miles away, and sorry, don't lend mine out because it's too easy to make a mistake in usage.
Just guessing there are many available with people willing to help in your local PCA chapter, maybe try posting in that region's section.
Something to be aware of when you recode with Durametric Pro, it is possible that by removing any module you will get a fault through
the DME checking for the module, ie. you may be better off recoding TPMS in the DME while leaving the module connected. If recoding with
module disconnected doesn't work, try reconnecting the module. Also, I have noticed that once you recode/reconnect the DME, it sometimes takes a stop-restart cycle to reset,
ie. if you recode with the module disconnected and it doesn't work after starting the car, turn the car off, key out, and restart and check.
If it still doesn't work, reconnect the module, recode the DME again, do another start, stop, key out, start and check.
This is why some people think the pax weight sensor/seat belt/airbag recode doesn't work.
4th Gear
Something to be aware of when you recode with Durametric Pro, it is possible that by removing any module you will get a fault through the DME checking for the module, ie. you may be better off recoding TPMS in the DME while leaving the module connected. If recoding with module disconnected doesn't work, try reconnecting the module. Also, I have noticed that once you recode/reconnect the DME, it sometimes takes a stop-restart cycle to reset, ie. if you recode with the module disconnected and it doesn't work after starting the car, turn the car off, key out, and restart and check.
Understood. I am being told the shop has tried every way they can think of to handle it, but it would not "take". Hoping for somebody close that can take the time to go thru these steps to verify.
