Michelin SS Tire Vibration?
Getting ready to put some new rubber on my 2011 Cayman, had decided on Michelin SS's. But was told by one tire vendor that he's had complaints that they vibrate over 70ish and recommends the Porsche N rated PS2's.
Any advice or suggestions welcome. Its a DD car and I live in AZ, so don't need all season, just HP summers. Ride comfort and handling trump out saving a few $$'s or longevity.
Tx Machog
Tx Machog
I'm on my second set of MPSS (Cayman R 19s) and have no complaints as far as vibration goes. As long as they're balanced properly shouldn't be a problem. I track regularly on them and like them.
When having your tires mounted and balanced, be careful to make sure that the mounting goop has dried before driving the car, as the tire may rotate on the rim, causing the tire to not be balanced.
Tx Machog
Tx Machog
In the case of imbalance, this arose because either the initial balance was not done right or the wheel lost a weight or as the tires wore and got of balance. (The wear removes the heavy sections of the tread.) A rebalance eliminates the vibration.
Jim In St. Louis raises good point about the tires slipping on the wheel. Somwhere in the Porsche factory manual there is a caution about this... let me see if I can find it...
Here:
Use only TIP TOP Universal, order No. 593 0601 (3.5 kg bucket) or Contifix as the mounting paste!
and
When mounting tubeless tyres, check the sealing surface of the tyre and the disc wheel for cleanliness and any signs of damage. Bear in mind here that the bead base performs the sealing function on tubeless tyres. If the bead edge has to perform the sealing function, air can escape when the vehicle is driven aggressively.
When mounting the tyre beads, use only the prescribed tyre mounting pastes. The following can occur if an unsuitable mounting paste is used:
• twisting of the tyre on the rim,
• fracture of the bead core during mounting,
• damage to the rim surface by aggressive substances.
If Contifix is used, apply sparingly to the tyre beads (due to risk of the tyre turning on the wheel). If possible, the vehicle should not be driven for 24 hours after tyre mounting or matching.
As for how a non N-rated tire will work for you and your car I can't say.
BB, I deserved that!
But the difference is so little, says if I go with the N rated and they have a vibration problem, bring them back no issues. If go with the non-Porsche approved and have problem I have to suck it up-or take to track days for 3 months until I trash them![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Machog
Machog
