Performance shifter cables
Old Aug 19, 2013 | 03:11 PM
Numeric Racing's Avatar
Numeric Racing
Basic Sponsor
Default Performance shifter cables
I'd like to share some photos of a Cayman track car with a set of Numeric Racing performance cables that we installed for Reeves Motorsports. It was time to replace the shifter cables in the 2012 Cayman when the OEM cables had failed so early on. We specifically designed and manufactured our cables with a larger diameter cable and metal components to withstand the conditions that cause these type of failures.
The following weekend after installing the cables Reeves' Cayman was tested at the track to determine the outcome. It was quite obvious the vast improvements the cables made after the first few laps. The driver Mr. Holcombe explained that the cables tightened up shifting and provided a more direct gear engagement. Also, less effort was used for shifting and more accuracy between gears. It was a complete transformation without any noticeable noise. Even with the Numeric shifter installed the enhancements were extremely noticeable and very fulfilling!
We appreciate all the feedback gentlemen. Thank you!
