First DIY Oil Change question
Any advice would be much appreciated. Thanks in advance
Steve
Steve
We moved from MA in January of this year so it really has been a short time. I miss our friends back East and the fresh seafood.
Most of the roads around here definitely afford for some great visibility both in a straight line and around corners so it really does offer many opportunities for spirited driving. But there are some roads that are on very hilly terrain and often the only way you know a corner is coming up is by watching the road signs. There are some off camber corners too which can raise the hair on your neck depending on how hot you come into the corner.
If you drain overnight, expect to drain slightly more, which will require a corresponding slightly increased fill to get to the "full" line on the indicator. I find an additional 8 oz is needed, but YMMV.
Each segment is 0.42 quarts, technically, anything between the arrows is ok. If you put in 8 quarts after an extended drain, you should be close to the 'full' arrow. If you 'need' to be at the full level (like me
), just adjust as you see fit in 1/4 quart increments.Oil level is not as critical on the Boxster as it is on a full dry sump. That doesn't mean to go ahead and throw in another quart in just for giggles, but if you go to the top line, beyond the full arrow, it's no big deal. My factory fill registered on the top line- who can argue with the Fatherland?
DO NOT over torque the LN plug. You will drive the plug threads past the tapping on the pan and the plug will just spin in no man's land without tightening--19 ft. lbs is it.
BD
Drain for 45 min. = 8 qt. total (including oil filter housing)
Drain for ~4 hrs = ~8.5 qt.
Drain overnight = 9 qt.
EDIT: changed wrong numbers above.
http://www.pelicanparts.com/techarti...Oil_Change.htm
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
