noise from front of my 2008 cayman s
I just bought a used porsche cayman s. At random times, but almost always shortly after I start the car after a long cool down, I hear a metallic grinding noise from the front of the car. It almost sounds like a high pressure of fluid going through a narrow pipe, but it sounds like some sort of a grinding noise. Is this normal on a porsche?
The reservoir is at the front, left, top of the engine compartment. You will need to remove the top cover to access it.
