Help: Key stuck
Old Jul 29, 2012 | 03:52 PM
Schmidts Cat's Avatar
Schmidts Cat
Originally Posted by acadian_dad
Should be a wire tool in your fuse box cover to release the key lock. Or apply 12V to the pull out red post in the fuse box (ground return to the door latch on b-pillar) - eg with boost cables.
I just tried the red pull-out "lead" in the fuse box.... it let go of the key, but no dash lights, window op, or frunk pop. I hooked it up with jumper cables to my SUV.
Old Jul 29, 2012 | 05:45 PM
the_vetman's Avatar
the_vetman
Schmidt, did you end up getting a Braille 21 lb. battery?
Old Jul 29, 2012 | 08:52 PM
acadian_dad's Avatar
acadian_dad
I had similar issue as well on my C2S. I ended up using a 12V male-male cable from a portable battery pack into the cig lighter just long enough to pop the key and the frunk.
Your old GT3 has a brand new interstate in it - so far no issues ...
Old Jul 30, 2012 | 12:41 AM
Schmidts Cat
Wish I hadn't sold either of my 3s! I didn't get a battery yet. At this point I'm just gonna call P-Roadside... maybe next week, still too busy.
Old Jul 30, 2012 | 12:44 AM
the_vetman's Avatar
the_vetman
Ohhhhhh.... I didn't realize that the problem was still unresolved. Understand the "too busy" situation... Good luck.
