Help me ID this built in Radar Detector
Ok, I'm the third owner of this car. This radar detector was installed by the original owner. So I'm assuming it was circa 2006 or so. Does anyone recognize the control **** in the passenger foot well or the "snake head" LED/speaker units on the sides of the instruments? (SEE PHOTOS) The control **** turns the system on when moved forward or backward by one detent from the central, 'off' position. The snake heards chirp and red LEDs light up when the system turns on and when a signal is detected. The left side seems to indicate front radar signal and the right indicates rear. The LEDs are red. If they were blue I would instantly assume K40 based on what I've read. I just want to figure out what I've got. Perhaps get a manual online...
http://i583.photobucket.com/albums/s...r/a3a7070d.jpg
http://i583.photobucket.com/albums/s...r/75426a6d.jpg
http://i583.photobucket.com/albums/s...r/06e160f0.jpg
http://i583.photobucket.com/albums/s...r/915467ac.jpg
Thanks!!
Thanks!!
K40, k40.com, 2000 series, hope this helps, those are the optional pods.
http://www.k40.com/filebin/pdf/1000_2000_OWNERS.pdf
