Draft Brake Rotor replacement DIY
Fellow Boxster owners,
I just wrote a DIY draft on replacing brake rotors on the 987.
I welcome readers of the draft to give me their comments on my words.
(Send me a PM)
After it's all fixed up, I'll create a DIY document on rennlist.
You can see it at:
pkvista.com/TraqJunk/brake.pdf
(Send me a PM)
You can see it at:
On a related note, I recently came across this write-up for replacing brake pads as I was/am looking to replace both my front pads and rotors:
http://www.bombaydigital.com/boxster...es/change_pads
I ordered the parts from Suncoast: $267 for front rotors and $116 for pads. Thanks for the write-up, this will help complete my project!
Jason
Jason
Excellent article cited above, except for (IMO) one quibble:
I say do NOT open the bleed valve to compress the pistons. Rather, insert the old pad sideways and use it as a gentle lever to compress the pistons. (opening the bleed valve gives a chance of problems -- dirt, air.)
