Help with TMC warning
I have a now constant error message "TMC inactive learning". Recently had an indy repair a leaking tire which afterwards is fine pressure-wise.
Has anyone a suggestion on this problem?
Thanks in advance.
Thanks in advance.
I only spent a few weeks with my Cayman S and its TPMS (I liked the feature!) so I can't say for sure, but a WAG is one (or more) TPMS sensor batteries are flat. I note your car is an 07. The local dealer service manager tells me the TPMS batteries can start to go out around 4 years. Or the indy damaged or removed the TPMS sensor in the wheel when it repaired the leaking tire.
Sincerely,
Macster.
