A little track protection
In preparation for taking the car to the track for the first time next weekend, I thought it prudent to protect the front end of the car and mirrors. I bought a really nice bra and mirror covers, in black. The fit is great. They actually used my car to create the pattern. I used to tape up the front end on my previous car (308 GTS) but this gives me much better coverage.
I will report back after the weekend but I think this may work out well. I never did opt to get a clear bra.
Phil
Phil
Here are some the pictures of the new bra and mirror covers...
Phil post some pictures, this is the first I've heard of a bra for the Spyder! You might considering putting some painters tape behind the tires, once the tires get hot small rocks and sand will stick to it and accelerate it into the painted areas behind the tires. You should also put a clear bra on the rear flares, nothing installed from the factory.
Sorry, you posted pictures before I responded. How much?
I purchased it from speedlingerie.com in Mountain View CA. The front cover cost $599 and the mirror covers cost $139. You can pretty much get them in any color you want but went with the black.
Afshin - I thought about a clear bra on the flairs but didn't want the edge to wax around nor the special wax for the bra. I will probably still put some blue tape on the back edge of the wheel wells like you suggest. Thanks,
Phil
Phil
one of the best things you can do for our cars for both street and track is to install grills in front of the radiators. Hit a bird square in the left intake on my Cayman and my grill prevented damage to that radiator.
I built mine myself and plan to do the same for my Spyder. Get a piece of poster board and take your time and cut a template (right and left side are the same. At home Depot on the gutter supplies isle get some metal mesh gutter guards ( they come in 6" x 3') the cost is bout $3.00 per piece. One piece will be more than enough to do both sides and a second one to do the center if you have a third radiator. use your template for a guide and cut out the necessary shape. I then fine tune mine with a bench grinder to take off sharp edges. Paint them black and install either behind the grills ( a little tricky or in front of them with black tie wraps. Someone sent me some rubber edging that I used on one car and will use it on my other when I find a source. Project takes a couple of hours, looks good and is great protection to your radiators. Have not noticed and increase in coolant temp with the grills installed even in this past hot Summer.
Cheap insurance really.
Phil, one trick I learned is have a custom install done that leaves very few edges that you'll need to work around. For example, my entire hood, fenders and front bumper are covered with a clear bra. I use the same carnauba on the bra as the paint and I don't have to take any special precautions or really worry about edges. The rear flares have one single visible edge which is a straight line at the top. If you wax in the direction from the bra to the paint you won't get any wax build up on the edge. The bra is installed right over the sticker so you eliminate those edges too.
Best regards,
Dino
Price update, my mistake, mirror covers are $189 not $139.
Dino - The bra is only going to be on the car for the track, so I am hopeful that there will not be any wear marks. There is also some basic maintenance to clean it which I intend on keeping up with. Thanks, Phil
Phil
Phil
Nice! Pics of the 308??
I agree that protecting the radiators which sit very low and have no protection is very important. I installed a set of mesh guards shortly after bringing my car in for service and seeing how much junk was in there. The guys at the dealer had suggested buying a set to protect the radiators and keeping the leaves out in the fall. They work beautifully and give the intakes a more aggressive appearance. I purchased mine from http://porschemesh.com/boxster.html.
