Wheel offset
Old Mar 22, 2011 | 04:16 PM
Nader Fotouhi's Avatar
Nader Fotouhi
Default Wheel offset
I have read that the rear wheel offset for Cayman S is 43. is this correct?
Old Mar 22, 2011 | 08:00 PM
Bill Lehman's Avatar
Bill Lehman
On my 2007 Cayman S with 18" wheels, rear is 43 and front is 57. On my wheels this number is cast into the wheel at the valve stem. On our other 2009, no numbers are visible.
Old Mar 23, 2011 | 12:38 AM
altonj's Avatar
altonj
It depends what you want to do....
I have 10.0 et38 and 10.5 et38, with aggressive rear camber I can still fit a 5mm spacer on the 10.5's with a 275 tire. I have also done 11.0et 38 with a 295.......
For the front I have 8.5 et44 and 9.0 et44 which can both take a 5mm spacer with the camber we run and a 245 tire.
Cheers
Old Mar 23, 2011 | 01:29 PM
Jim in St.Louis's Avatar
Jim in St.Louis
If you check your owners manual you should find the wheel offsets.
Old Jan 2, 2012 | 11:26 AM
danielmellen's Avatar
danielmellen
if you're running stock wheels, your offset in the rear is likely 46mm and is stamped on the wheel near the valve stem (along with the wheel width).
Old Jan 2, 2012 | 02:06 PM
Dave DE's Avatar
Dave DE
My '06 cayman S has 18" wheels with the same offsets Bill stated above, 43 rear and 57 front.
