whine from the rear of a cayman
I bought a new 07 Cayman and have done only 9K miles. Shortly after its first service at the dealer it developed a whine from the engine and/or manual transmission. It only shows up when I make a very slow turn - like in a parking lot. When I park after this, the noise can be faintly heard from the idling motor. Any ideas? I haven't taken it to a dealer yet because the nearest one is > 2hrs away.
Thanks in advance for any useful ideas.
Swifty
Swifty
thanks for the advice
Krokodil,
I think you are absolutely correct. When I pay very close attention to the noise and when exactly it occurs, it is entirley consistent with a power steering pump issue. I can increase the whine, just sitting stationary but pulling on the steering wheel.
A couple of other questions...How can I check the fluid level, everything is sealed off except from below I guess. Second, how much do these pumps cost to replace. I have a feeling that is what I will have to do.
I don't track the car.
Thanks again.
JW
Thanks again.
JW
Krokodil,
Thanks again.
JW
Thanks again.
JW
To access you must remove the carpet on top of the engine, remove the aluminum engine cover, and then remove the cap on the fluid resevoir (forward part of the engine bay).
Cheers,
noise fixed
Thanks Krokodil for the advice. The pump fliud level was low - added some CHF 11S and the noise has gone. Car is still under warranty so now I will take it to the dealer to find and fix the leak.
Swifty
Swifty
