Anyone using only the center wind deflector?
My 2008 Boxster doesn't have a wind deflector and the seats seem to fill the rollbar openings so much that I wonder if I should get only the center clear wind deflector and skip the two roll bar baskets. Anyone have experience with using only the center piece? I did a search and found someone mentioning a whistling sound from the baskets and a few mentioned rattles from them that they solved with some velcro. I would appreciate any suggestions on the subject. Thanks
I use the entire wind deflector (center piece and "baskets) and I have not experienced any whistling or rattling. I suppose someone could always end up with poorly fitting pieces or something.
So far I'm happy with the complete system, but you can always start with the center piece and add the baskets if you need to later. Good luck.
I can't really tell the difference between wind deflectors/no wind deflectors, theres still a lot of wind, so I just leave mine off so they won't get stolen if I park the car with the top down. They are very expensive.
Now the wind deflectors on 996 Cabs, really work.
Porsche Boxster 987.1 (2006) Wind Deflector Mount Kits
