Anything special about rotor replacement?
Is there anything special about the rotors? Is there a large nut that requires mega torque to remove? The ones on the 928 are held by two bolts and are removed by two other screws to pull off. Is it similar on the Cayman?
I don't have his car at my place to check it out personally, but wanted to give him an answer over the phone before he makes the trip to my place.
Also, it would be great if you recommend a good source for brakes/rotors
Thanks in advance
Tarek
I had to use a breaker bar to loosen my original bolts, but other than that it was pretty straightforward. Bolts are torqued to 63 ft-lbs. The rotors are held on by 2 small phillips head machine screws.
For best prices on OEM replacement rotors I would check with either Suncoast (east coast) or Sunset Porsche (west coast).
You might want to check out this DIY article on Planet-9 (it is for a Girodisc rotor, but same principle):
http://www.planet-9.com/reviews/caym...ed-rotors.html
