Vertical separator rattling on hatch
My 2007 Cayman has a rattle in the vertical curtain, on the hatch that attaches with two *****, that separates the storage compartment from the passenger area. I took it the dealer and they said it was normal. Does anyone have any solutions or suggestions other than turning the radio up or leaving the divider off?
Jim
Jim
When I had that issue on my '06, the dealer installed a couple adhesive felt pads on the curtain where it contacted the the silver body parts of the interior. I do not think that was an "official" Porsche fix, but it was effective.
Sounds like your dealer is being somewhat lazy.
Brian
Brian
Jim, I had a similar rattle on my '07 and removed it with the same method mentioned above but I used a couple of rubber stick-on pads about 1/4" dia each and about 1/16 thick. The pads are actually meant to be placed under vases, objects'd art and other stuff to protect tabletops. Same function as felt but hold up a long time and keep their padding better. Get them at Home Depot, etc.
Brad
Brad
