Solutions for IMS Failure?
I'm considering adding a Boxster to the stable within the next year or two and I'm working on establishing the right budget for the purchase.
One issue I continue to read about is the IMS failures on the newer engines which appears to be due to the car sitting for extended periods. Since I won't be using it for a DD I'm thinking that IMS failure could be a potential problem for long term ownership.
Are there any proven aftermarket or factory options available that solve this problem?
Would an Accusump be the solution or something else?
Any car that sits for long periods of time without being driven will deteriorate. Seals and gaskets dry out, moisture accumulates in fluids, batteries run down, etc. How infrequently are you planning to drive the car? If it's just a weekend car, you probably won't have any issues just make sure you bring the entire car up to full operating temp (i.e. avoid short trips).
Second, I don't think the Accusump product would affect whether you experience an RMS failure. That sump is design to provide adequate lubrication under hard cornering and at cold engine startup. RMS failures (the gasket between engine and transmission seeps) wouldn't be affected by this. This type of problem seems to be far less prevalent with the latest seal design even then tends to be more of a nuisance that leaks a few drops of oil rather than a catastrophic event.
Chris thank you for the reply.
I may be confusing something. Aren't there known issues with bearings and other metal to metal contact surfaces which can lead to engine failure?
I guess my biggest concern is that many of the major issues with the earlier engines required a complete engine swap rather than repair. Is this still the case or has Porsche worked through many of the issues?
As far as sitting, it may get driven a few times a week but may also sit for weeks on end depending on work schedule. It will also sit all winter (4.5 months).
Phil
The former is a leak. As Chris correctly pointed out it is a minor leak and many live with it until in the case of a manual transmission equipped car the clutch needs doing at which time taking care of the RMS is a small additional bit of work.
The IMS and its bearing is another thing.
Many owners continue to drive these cars with no issues.
There is at least one aftermarket company offering an enhancement that addresses the IMS bearing weakness. I do not have any experience with this enhancement and can not provide you with any assessment of the risks. Some owners have had this done, or done it themselves and so far there have been no problems reported. But the number of cars with this enhancement applied is small.
To have this enhancement installed is not cheap. The car's transmissioni must come out. Some engine disassembly required. No case splitting but the job does require gaining access to the end of the IMS where the problematci bearing resides.
Before you proceed much further perhaps you should search out info about this enhancement and read up on it. www.flat6innovations.com IIRC is the web site where you'll all you want to know or links to where you'll find all you want to know. (Also, search for Mike Focke's web pages containing much good info on Boxsters.)
If this enhancement sounds like something you are interested in, what you can do is if you believe a used Boxster requires this enhancement to provide you with the peace of mind you require is to get a good estimate of what this would cost to have done, then attempt to factor this cost into the value of a good used car you find and see if you can reach an agreement with the seller of the candidate car. Then if you are successful have the enhancement done.
Sincerely,
Macster.
Thank you gentleman, that is exactly the information I was looking for. I'll read up on the IMS enhancement and determine the best approach from there.
I have also been searching for a more active Boxster Forum for US owners, any suggestions?
Hey Afshin,
Supposedly there were some improvements in the bearings with 987 Boxsters from mid 2006 on. Whether that has eliminated the problem, its probably too early to tell, as many of these cars don't have a lot of mileage. You could also eliminate the whole IMS issue if you look for a used car with DFI motor ('09s on). Although, possibly the DFI motors are too new to know if they have any issues of their own to consider.
While there have been IMS issues with everything from 986 Boxsters, 987 Boxsters, 996s and first generation 997s, I still see a lot of 986s and 996s on the road so hopefully that is a good sign that these cars are pretty hearty and the IMS problem is not that common.
Not sure if you've driven a Boxster, but they are really a blast especially with the top down and a beautiful day.
Best regards,
Dino
Best regards,
Dino
Thanks Dino.
I haven't driven one yet but based upon everything I've read I am certain I will really like it. I've always been attracted to well balanced cars that become an extension of the driver although I readily admit that the cars I have owned really don't fall into the category. I won't drive a Boxster until I'm ready to buy one, the last thing I want to do is make an irrational decision & sell my 928.
My goal is to pick up a new or used Spyder.
Thanks Dino.
If you are interested in the recently released Spyder which has the DFI motor, IMS is not an issue at all. Its a completely different engine design.
I think you can enjoy a 928 and a Boxster. They are drastically different in feel and purpose. Its been years since I've driven a 928, my Dad had an 86.5 when they were new and it was a great long distance cruiser. The Boxsters are a completely different animal, but you will see that for yourself once you get behind the wheel.
Best regards and good luck on your Boxster search,
Dino
http://www.ppbb.com
is pretty active.
Another is:
http://www.babblers.org/
And yet another is:
http://www.6speedonline.com/forums/index.php
One more:
http://986forum.com/
Sincerely,
Macster.
Related to the IMS issue. There is a very informative 2 part article relating to the IMS issue in Excellence magazine. I'm trying to remember the months, but I think it is the June/July issues or maybe the July/August issues. Anyway, some great info there.
Thank you everyone, I've already started reading about this last night. Seems that solutions are available for a reasonable price (~$1,500). I just need to research how many have had the solutions installed for an extended period and if they've checked for any issues after installation.
The number of bearings installed is north of 500. The procedures to support the IMS retrofit into an assembled engine were developed in early 2009.
The actual bearing has been in use in engines that were disassembled and updated since 2007. The technology is well proven, several engines have been disassembled after installation for evaliuation purposes, including the engine that had the very first bearing ever applied.
Results have been positive, else I'd not be utilizing the technology in EVERY engine that we assemble/ update.
