Missing gauges
Old 03-14-2009, 03:31 PM
ADias
ADias's Avatar
Default Missing gauges
If I am not wrong the Cayman does not have oil pressure and oil temp gauges. Does it display that info on the digital readouts?
Old 03-14-2009, 04:53 PM
KS-CS
KS-CS's Avatar
You are correct, it does not have oil pressure/temp gauges, nor does it have a digital readout of temp or pressure; it just has a digital oil level meter (and I presume an idiot light for pressure/temp problems).
Old 03-15-2009, 01:36 AM
ettsn
ettsn's Avatar
It may be possible to swap in a 997 cluster. It was an easy swap to put a 996 cluster into a 986, but I don't know if/how much harder it will be in the newer cars.
Old 03-19-2009, 06:20 PM
Thundertub
Thundertub's Avatar
Attention aftermarket folks!
Opportunity knocking here!
2-gauge cluster add-on with proper sending units. Could be integrated onto the dash or the left A-pillar or some place visible and logical. If the car is equipped with the dash top timer from the PASM Sport, then a 3-gauge cluster that integrates the timer and looks factory original and fits in the same location...
This may be a ENZO. I didn't look.
Quick Reply: Missing gauges
