2006 987 IMS Issues
Sorry, couldn't find anything by doing a search. Was the IMS issue improved/corrected with the 2006 "S" model or did that not occur until the '07 models came out. Got differing comments from some supposedly in the "know".
The IMS/RMS issue is alive and well in all non direct injected porsche engines. Many on other boards have had recurring problems. There was an improvement in I think 05 for the 987 and maybe tweeks since. The IMS issue is still there more so in the 987 because of the lack of rear engine support. Excellence also did an article on this during the past year. Will be interesting to see if the new engines without the IMS will cure the RMS in the 987 but without the IMS it should be more reliable. During warranty is not a problem as porsche knows of the design flaw (would never admit it) and will cover it but after warranty issues have buried some owners.
Latter 987s have beefed-up components...Porsche has known about the problem for awhile and the '07s & '08s while not 100% immune from problems (what vehicle is?) are the best yet. And time will only tell what problems the DFI cars will have since again, all cars have some problems.
Will be interesting to chart the problems on the 07 & 08's when they get some miles on them. The problem is made worst by the low miles most P-cars have. When problems arise many are out of warranty. One would think that Porsche, who knows the design flaw, would cover IMS failures however, that is usually not the case. In any event, we can be fairly sure that removing the IMS on the DI engines will cure that problem.
Intermediate main shaft and Rear main shaft. Both have been a concern for this run of present Porsche engines. Excellence magazine did an article on the failures and why this year. There are folks who claim to fix the problems such as Jake Ruby and he now has a recent post on this and other failures on this board under 986. Even on the 987, Porsche has reduced the amount of metal in certain parts thus adding to the stressors. The IMS is a design flaw and Porsche is aware of it. Some on other boards have had multiple failures on the same car with new engines. These engines do have their issues....
Soltino,
If you are looking for the Jake Raby's post it is extensive so will not copy it with all its pics but it is under Boxster/S and titled: Is it really IMS failure... Carnage with pics and details.. Actually, this is another Mass engine failure that was new to me. It also is fairly new to Mr. Raby who, rebuilds many Porsche engines with beefer parts so failures are elimated or kept to a minimum.
Soltino,
Don't really understan your post to me.
I'm guessing that the link i posted did not show or did not work for you.
tino
