TMS screwy
Old Aug 28, 2007 | 09:50 PM
gerkebi's Avatar
gerkebi
Default TMS screwy
I can't get the tire pressure monitoring system warning light to go away. I've tested the pressure in all the tires very accurately, and it still insists I am down 4 pounds on the right rear tire. Doesn't make sense, if my gauge was wrong it would be wrong on all tires. And I've used two different gauges. Pressures are right, TMS is wrong.
Porsche's response? Go ahead and fill that tire up and make the light go away! In other words, we don't know what the hell to do so pump one tire up 4 pounds more than all the others. My dealer service writer and I both laughed out loud.
Anybody else have this problem?
Old Aug 29, 2007 | 03:40 AM
mdkod's Avatar
mdkod
3rd Gear
Yes, I have the same problem. It's worse when you are on the track. TMS goes crazy. Nothing but flat tire warnings.
Old Aug 29, 2007 | 08:32 AM
Bob Rouleau's Avatar
Bob Rouleau
Still plays with cars.
Did you try and teach the TMS new settings? It worked for me although on track with lowered starting pressure it freaks out.
Old Aug 29, 2007 | 09:17 AM
Budweiser's Avatar
Budweiser
Below brought from other forum.
Mine did the same **** yesterday. I added air and still could not clear message. After checking an old post from Sante Fe I went into the menu and re entered the tire size and type-winter/summer. There was a message indicating LEARNING. it lasted about 10 minutes and then cleared the error message and read the appoximate pressure. ( Not totally accurate acording to my 50.00 gauge from hutcherson pagan.) In any case I am convinced that this is the way to clear the error message. The dumbass local dealer said that I would need to bring the car in to reset the computer. The long term expets on this board know more than the dealers.
Old Aug 30, 2007 | 10:37 AM
gerkebi's Avatar
gerkebi
Thanks, guys. I'll try that today. I did notice on the track the system is worthless, which I can live with, I just hate that stupid warning light being on all the time when I'm on the road.
Old Sep 12, 2007 | 09:59 PM
gerkebi's Avatar
gerkebi
I did that exact thing and it worked like a charm. Thanks, guys!
Old Sep 13, 2007 | 01:31 AM
McGarrett's Avatar
McGarrett
I had the same problem. I finally noticed that the pressures where below what was recommended on the door jam. It seemed that all tires were loosing pressure over a period of time.
After filling them back to the ( Door jam specs- 30 front and 37 rear) the problem went away.
2007 Cayman. 17" wheels.
