Bumper removal
Old Apr 30, 2007 | 10:05 PM
ASilverBoxster's Avatar
ASilverBoxster
Default Bumper removal
A friend of mine needs me to remove his front bumper cover and i was just wondering if anyone has done it? and if so could they give me some basic directions....
Old May 1, 2007 | 12:49 AM
SpDfReAk980's Avatar
SpDfReAk980
Remove the wheels, the "front half" of the front wheel liners, side marker lights, headlights, front trunk trim (just the really long side pieces and the very front latch trim piece, there is a plug connection that must be undone on the passenger side near the radiator fan (after the wheel liners are out), if you have headlight washers the disconnect point is in the driver's side headlight area, next to the headlight connector, black rubber hose, easy disconnect. there are a bunch of screws on the bottom (fairly obvious), there are screws, one on each side, going straight up where the side marker lights are, a couple where the front trunk trim goes, those are pretty obvious too one the trim is gone. Now this one is really hard to explain, last thing though, where the long front trunk trim pieces connect to the front trunk trim piece, that is where the bumper meets the fender, now at where they meet and you will see a clip thing that is bent at an angle with small hole in the clip, get a right angle pick and pull it straight out towards the center of the car (one on each side), and off the front bumper comes, easy, that is the best i can do off the top of my head
