SharkWerks Project Cayman S
GT3 player par excellence
yes, the strut in the *** of cayman is inferior to the wishbones on the lotus.
you drive them both, you will see the difference right away.
now i just got to get my lotus to pick up another 1.5 seconds per lap, then i would match my cay s lap times.
tell james, he need to drive with NCRC and TM, not just HOD. they are too tame and slows his learning curve.
Alex - Outstanding photos! Congrats on the new Cayman project, please keep us posted on how development is progressing. Great choice on color too!
- Jordan
- Jordan
Originally Posted by sharkster
I've been using the GT3 seats for years in 996s and they are _not_ for everyone in terms of fitments. Try them first for sure.
Also, what wheels (and size) are those? Did you like them on the track?
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Which Lotus did you get? The SC'd one?
I'll tell James for sure... the group her ran with on the weekend was using split timers and kept resetting his timer! Bummer!
- Jordan
- Jordan
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Originally Posted by objectuser
Do you know what body types typically fit the GT3 seats the best? I've been trying to find some to check the fit (I'm in Dallas) but no luck so far. I'm 6'1" and 190.
6,1 and 190 _should_ be ok. It's on the edge tho...
Yeps the rear struts
james has an XT timer, he didn't set it right. multiple beacons is ok, if he set it correctly, his reader will only pick up the beacon at start/stop.
18s and the tire choice is so much better for that size... They're 10.5s in the rear and 8.5s in the front.
10.5s, eh? Cool! What's the brand? They look like Kinesis.
Which side of the edge? Am I on the tall side for them?
if your waist is no bigger than 36" and your rear is "normal" sized for a 36" waist, you will fit perfectly.
gt3 seat sits lower than oem cayman seats, so if you fit oem seats, you will not be too tall for gt3 seats.
