PCCB Weight Savings Per Axle?
Granted I'm not good at searching, but I looked and couldn't find any data on the performance improvement earned from saving 10#/corner with PCCB. It must be measurable, seeing as how competitors will go out of their way to save a pound or two of unsprung weight, particularly if it's rotating unsprung weight.
It would be very interesting to get good data points comparing a Cayman or 997 with and without PCCB, including acceleration, lap time (autocross or tight track) with data acquisition, and braking distances. I know it's out there, but does anyone reading this have it & is willing to share it?
I don't have real data; however, Donny and GH Sharp from Richmond area (or was it North Carolina?) were campaining a CS with PCCB at the beginning of the solo season, which I hear they gave up now as it is not competitive in the SS class. They competed locally against boxsters and may be one or two CSs occasionally and they put 1-2 seconds difference to all. That says nothing about the PCCB of course as they are both very good solo drivers.
I think the real performance benefit to PCCB is its resistance to fade at the track. This durability is the key, as positioned by Porsche, in endurance races. Beyond that, at my level, such savings do not have much meaning.
GT3 player par excellence
correct usage of rotor, pads, fluid.. you should not have fading "steel" brakes.
if you must spend the money on ceramic to reduce wt, look into brembo GTR breaks. $12k/set inc. calpers. amazing stopping power.
GH might be a good person to ask about the benefits of PCCB. Those 1-2 second faster lap times are no data point, since I'd expect GH to be 1-2 seconds faster than me in my own car.
For those competing under a set of rules (like GH), the PCCB may be allowed but the Brembos would not - or would bump someone into a highly modified class.
my buddy regret he didn't get PASM for ax, as PASM is ok, but aftermkt coil over will put him in another class.
Originally Posted by fletch
Porsche claims a weight savings of about half for the rotor weight. Anyone know how many lbs that is?
If you're comparing to the standard Boxster/Cayman S brakes looking to save unsprung weight, then there is no weight savings. This is because the stock 318mm brakes weigh about 10lbs less to begin with. The extra 3lbs plus weight in calipers, pads, etc. make it about a wash--I'd say within a pound. I don't have the weights in my head for the rear, but similar.
Like mooty says, if you're not fading the steel brakes (not pads/fluid), then you don't need the bigger heat sink/thermal stability of the larger rotors.
It's a glass half full or half empty kind of deal. You could say the PCCB are waste of money and not really any lighter than the S brakes, or you could say that you have a significantly upgraded brake system with no extra weight penalty.
For me, I warped my S rotors, but I suspect that's more of a result of stupidity (laziness) and not letting my brakes cool down properly. What I would really like is to take on a project of making or finding 2-piece front rotors with aluminum hats.
