Harness bars?
GT3 player par excellence
Does anyone make a harness bar for the Cayman?
_________
not that i know of.
where can you mount it to? we have no "B" piller.
How about a roll bar? Mooty, you is yours coming along?
_________
my will start on 3/20. it will be very tight. but i was promosed that it will look very OEM.
btw, the harness bar will be very close the the top of the rear shelf depending on where the driver's shoulder is. the ht is critical for HANS to work right, but for MOST drivers, that ht is right at the rear shelf ht.... may conflict if not very close.
_________
not that i know of.
_________
MantisSport will have a belt bar this week for Cayman S. We also will be manufacturing adjustable front camber plates. Proto-types have been made and being fitted this week, up to 3 degrees
negative. Racers Edge has LEDAs for the Cayman S . Springs are still being
played with . We should have those figured out after the PCA race in Altanta. Billet rear upper strut bearings, 1.5 qt sump extension, Roll bar and roll cages custom fitted only. Headers and exhaust system proto-typing at the time. Contact Ernie @ mantisracing.com
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
