Hot Cabin from Engine Heat?
The difference between the Cayman and other mid-engine cars is that the engine normally sits "outside" the cockpit area with some sort of heat sheild in between and lots of sound deadening material, i.e. NSX. However from what I've seen of the Cayman there is no such division that would assist in maintaining the engine heat out of the cockpit.
Having said that, Porsche hopefully already thought of that and found a solution.
Only time will tell....
I have a feeling that if heat were a real issue, its not something Porsche would have missed in their extensive testing.
Then again, maybe we will save a few bucks by not needing to order seat heaters.
I'll say it again, that on my Boxster in the middle of the summer, stop and go traffic with it 97 degrees out, the bulkhead behind the seats was "warm" and that is it!
Close the top and put on the air and you would never know!!!
The Cayman can be no worse!!! The only "hotness" on the Cayman is going to be that back window during summer acting like a green house, and Porsche now does make great AC that can overcome even this heat!!!!!
Just picked up 2017 718 Cayman Graphite Blue from the Porsche Experience Center, Atlanta in July. Drives like a dream, extremely fast Very happy with it. Large frunk but rear trunk is very warm after even a short drive 5 mile in 90' outside temperature. When you place hand on the rear trunk floor it is very warm even though I don't feel the temp in cabin with AC running. I think Porsche could have done a better job isolating temperature into rear trunk or rear area period.
Otherwise, very happy. Plan to do oil & filter change at 5K miles. Would appreciate a helpful link on how-to. If none can be found, I will post up one.
For what it's worth, this has never been an issue on my 2012 Cayman S.
