Foxwell Scanner Codes - Please Help
Does anyone know where to look up what the Foxwell Scanner codes refer to. Please help if you know what the following codes mean.
I have a 2006 Boxster S 18,000 miles and I am getting the following codes.
Front Control System:-
8042 Implausible signal - Front luggage compartment unlocking
POSIP Control System
C152 No Display Communication PSM control unit - drive
Rear Control System:
C128 No Communication - Communication PAS comfort control unit
Any help would be appreciated
None of those are giving you a Check Engine Light, correct?
They've probably been there for a while - various things could have triggered them. Has your battery been low or replaced recently? (a low/dead battery can trigger some faults)
I suggest clearing the codes and then rechecking your codes in a week, after you've driven the car a bit.
Thank you. As you say, no engine light and yes they have been there for a long time. Battery is 6 years old but car not driven much in the past. Was under impression battery was good but i will test it, could be the problem.
Sorry for delay, needed to get around to scanning the car again. 2005 Boxster S with 3.2 and M/T.
FWIW, I usually get the first two you listed there on my Foxwell NT530 scanner as well. I do not know what they mean, but they seem to be non-consequential. They’ve been showing up for over 100,000 miles of my ownership.
Hope this helps.
Hope this helps.
