PDK Issue
Today I had an issue with my PDK where I couldn't remove the key as the instrument cluster told me to put car in Park. I moved the shifter forward even though it appeared to be in Park and was ok until I tried to exit Park again. There was no movement in the button and lever was stuck. I pushed the lever forward to the dash and the button popped up and with more than normal pressure I can depress the button and move the lever to drive. The rest of the drive was the same, any ideas on what could be happening, the button doesn't reset unless I push the lever past the normal resting position.
