987.2 Boxster Rear Control Unit - PIWIS coding
Had to replace the Rear Control Unit in my 2012 987.2 Boxster S PDK because of water damage.
Have replaced the unit, but now it needs to be ‘coded’. I have a PIWIS (PIWIS4 42.300), but am new to using PIWIS.
Could someone who has done it before be so kind to run me through how I do the ‘coding’ with the PIWIS?
(I’ll owe you a nice craft beer or two if you’re in the neighborhood. Or can send if you give me your address![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Received 1,910 Likes
Hahaha.. nice one, you're in Tokyo!
Unless something has changed with Porsche, this module is considered a security device and iPASS codes will need to be entered into the network for it be coded. The process is laid out in the service manual as I've posted before for others that have attempted it, but without access to the Porsche network authentication, having a PIWIS is not enough to do this job. This is the same as making new keys. Therefore, my advice would be to get the car to the dealership for coding.
@ZuffenZeus I did offer to send! Thank you for taking the time to reply.
I had read many comments like “it is a 10-15 minute job with a PIWIS”, without mentioning that dealer codes are needed, so I thought I could do it myself with PIWIS.
I found back your earlier posts on the topic. To be clear, I am talking about the control unit under the seat, not the one behind the steering column.
