2006 Coding Questions
7th Gear
Got myself a 2006 Boxster base, 5 sp, 89K miles. This was an auction car I scored for $3100. I've got this thing in pristine shape now, runs perfect but I've some coding items I need some guidance on.
Got a new key cut for $720 from the dealer/indy and it works fine but the car remote key will not lock, only open the doors and the trunks. When I brought it back to the indy they said it may not be locking because an I installed an aftermarket carplay unit. The unit is wired like factory with a proper wiring harness. Is this something I can remediate with coding? Do I need to code this radio to the car to get it to lock? Upon indy scan, nothing appeared to logically fix it. Any other ideas on what might cause a remote no lock situation?
Second item is the TPC or TPMS feature is no longer displayed on the LCD navigation. I think this is something I can code back in. Anybody have experience with this? I saw a few posts that the Foxwell 530NT was the scanner/coder unit to get for a 987 Boxster.
Any feedback on the most cost effective but capable scanning/coding unit to buy?
Thanks!
Thanks!
Mansu944 (02-01-2024)
7th Gear
bump
Sorted the lock issue. TPC not displayed, seems to have stumped everybody
Bought an NT530 - good unit, but does not support TPC/TPMS. I can select if it's installed or not, and edit the wheel sensors ranges and Hrtz but I can't add TPC as an option on the cluster or gateway
Congratulations and enjoy your car. The Durametric Professional may be useful but others who have used it specifically for your needs may be able to chime in.
I have placed a link to the Durametric website that has a model feature matrix and also to another site with more detailed information by the floatingkiwi, including Gateway, Alarm and Instrument Cluster options.
Perhaps the key options need to be matched in Alarm? Does the Foxwell have access to any of these modules? Carefully back up everything a few times over before making changes.
http://www.durametric.com/modelfeaturematrixv6.aspx#987
https://docs.google.com/spreadsheets...htmlview?pli=1
Addendum. Just realised you sorted the key issue.
For TPMS, check the build using the VIN to see if it was an installed option. It wasn’t standard.
