Will 718 18inch winter wheels set work on 987.1
Front wheels match the 987 18” wheel for offset.
Rear wheels inner rim will be 3mm more inboard than the 987’s 19” (most inboard of the 987 stock sizes) and about 12mm more inboard than the 987’s 18”. Should verify that this isn’t a problem.
The tire sizes here have higher sidewalls than the 987 and so would suggest to go to the 987 tire sizes.
The following 2 users liked this post by audi49:
joliver3 (11-26-2023),
Woodman207 (11-25-2023)
Thank you! I assume the hub size is also the same? Thank you again!
Where is the “offset” actually measured? From the face of the wheel where is contacts the hub to the inner edge of the rim, (outside where the tire bead sits) ? Or ?
I think I read, that the Cayman 987.1 with 18” wheels, has a front offset of +57 (mm?) and a rear of +43 can anyone confirm?
Here is offset explained. Our wheels have a positive offset. And so a larger offset moves the inner rim inward further, e.g.
https://www.lesschwab.com/article/wh...el-offset.html
Aussie skypig (11-26-2023)
Woodman207 (11-26-2023)
I guess, going to wider wheels, one would generally have to choose wheels with less positive offset to retain clearance from brakes/suspension. (Not that I’m thinking of going wider)
Can anyone confirm the offsets I quoted are correct for a stock Cayman S 987.1?
The 17" wheels were standard for my 987.2 Cayman, but my car came with the wider optional 18" wheels that were apparently standard on the Cayman S in 2011.
Somebody will correct me if I am wrong here but I believe that 987 Cayman cars had a standard wheel set that was 17" and narrower than the larger-diameter wheels. I would think that these 17" wheels would be good for snow tires.
From the same resource, the optional wider 19” wheel offsets.
Porsche option 19x9.5 +46
Porsche option 19x10 +42
I found this website to be fairly accurate when trying to get a general idea of what car came with what wheels/tires as options.
https://www.wheel-size.com/size/porsche/cayman/2007/
joliver3 (11-29-2023)
