987.2 Steering wheel upgrade
My car has the standard non-multifunctional steering wheel. The previous owner installed a Dynavin head unit as a replacement for the standard CDR 30 radio and now I want to replace the steering wheel with a multifunctional one so I don't have to take my eyes off the road to change channels etc.
I have been able to locate a second-hand mf wheel but it's the wrong colour - brown leather - I need black.
Has anyone disassembled a steering wheel? Can my black rim be interchanged with the brown one or is the answer to dye the brown one black?
Odd question I know, but maybe ....
Wait is the steering wheel the same design? (pix are worth a 1000 words...) If so then yes you can swap the MF controls from the brown one to your black one. If they are different steering wheel design generations then probably not. You'll probably also need the MF steering wheel airbag harness vs the standard harness on your steering wheel. Can you give us a couple of pix? Thanks
Thanks Zepper. Yes, they are the same design. The MF was offered as an option and according to Porsche Centre, only one type of harness was supplied meaning that MF connections were left open on the standard wheel, so should be just plug and play! I've heard that re-coding might be required.
You'll also need an M12 triple square if the steering wheel bolt is the same as my 987.1
