987.1 Tiptronic question.
Whether in manual or automatic mode, in 2nd gear, light throttle, light acceleration, the engine drops about 200 rpm at about 2200 rpm, every time, for months now.
Some time ago I had this looked at by a Porsche independent shop amongst other things, they said they test drove it, they said the transmission shifts fine, I said "really?, ok" and let it go.
Is this a "thing", is it a torque converter lockup valve closing by design because of how the transmission is programmed to start in 2nd when warm... or is my car... "special" and an impending grenade?
Whether in manual or automatic mode, in 2nd gear, light throttle, light acceleration, the transmission drops about 200 rpm at about 2200 rpm, every time, for months now.
I'm surprised anyone that test drove it would say it's perfectly fine unless they couldn't reproduce the problem.
Take some video and repost.
I think the OP is saying it drops BY 200 rpm.
Apologies if I’ve got that wrong.
OP, the Tiptronic can be sensitive to gear oil going out of shear, although this usually results in slip/higher rpm. Have you change both the gearbox oil and it’s filter recently? If not, it may be worth considering.
The independent Porsche mech quoted me about $2k for a transmission flush ("we can do that if you want...") and water pump replacement about a year ago.
I've run this car to redline from 2nd to 3rd gear quite a bit in auto and manual and then into 4th (not redline :lol ), other than this quirk it operates completely normal, doesn't seem to "slip" anywhere to redline in any gear, been like this for the almost 5,000m I've put on it.
