According to parts diagram, available as 9G2.332.029.05 if you have an open differential, 9G2.332.029.25 if you have a limited slip. However, you have a concern about metal debris left inside the transmission.
thank you for your information, is there any equivalent from other than genuine part (after market), as I understand it is discontinued from the Porsche.
yes I checked it out in our agency, any idea how to find it used if possible ?
many thanks
I don't know anyone disassembling PDKs, given they cannot be serviced in the field (as far as I am aware). However, per my earlier note, you really need to be concerned about other damage and debris inside the transmission. There's more that's needed than an output shaft. For a second opinion, give California Motorsports a call. Good luck with this.
Thank you for your reply, yes I changed the Joint Flange already and it happened to me that there is oil leak after that (Gearbox Oil), I take it back to the garage and they are checking It again and I will keep you updated. Sounds like a serious problem in PDK and I will clarify that after a week from now.
